DARKSOFT JVS documenting and backup
Today I’ve tried the new pcb’s
I have to tie pin 27 of the “27512” to gnd, to stop the complaining of my programmer, saying that it wasn’t connected.
But aside of this... It works!!!
Well, almost...
I can read my TMP90, but I can write on the new IC’s.
They read 00’s so I think they could be wmpty, but from the first byte, it says that doesn’t verify the contents.
I have to recheck all the datasheets, in cause we left something.
I saw on the bin file that I read from my TMP90 that in some places it says 1.06 and in others 1.07.
That’s why I tought @darklord that my version was different.
Well, almost...
To write to an OTP the bytes have to be 0xff. "writing" involves setting a bit to 0.
That is correct if you read only 00s it means that it cannot be programmed at all :(
Maybe you need to do something extra to activate the CHIP in "WRITE" mode. Try forcing the OE pin HIGH so it wont allow any output. Maybe that helps.
Finally I got a little time to try this, fixing OE to High, but I got the same result.
Been trying to find "new" or nos TMP90's but no luck, everybody says that theirs are original and new, every time more expensive, but I can't be really sure, so... now it goes to stand-by.
Let me check the datasheet and see if I can see where the error comes from
Bumping up this old thread. If you have a Sega's JVS I/O with the TMP90PH44N, please check the 1st post of thread and if yours is not listed there, let us know!!! so we can preserve it.
Thanks!
