chacal231077
Konami Cobra System Never Dies
lets see it running!Konami Cobra System Never Dies![]()
Very good IdeaI have been thinking about making a BGA socket because of frequent failures of BGA chips on model 3 step2.0 graphics boards.
This may be fixed by socketing the Cobra board's BGA chips.
https://www.advanced.com/products/bga-socketing-systems/socket-adapter-systems
are any those used on any other device or are they unique to Cobra?I'd wager that the cobra's chips are compromised, and that bga rework (or a socket) isn't going to actually fix anything
I can find some off-the-shelf/obsolete stuff (IBM power PC, fifo ram, fgpas) but other stuff I haven't been able to source. Could just be obfuscated serial numbers but it's obfuscated enough to keep me from working on it lol. I do assume the fpgas aren't fried (those would be show-stoppers if so), but the bga parts on the video board under all the heat-sinks are dead-ends for me.are any those used on any other device or are they unique to Cobra?
It's been a LONG time since I hooked one up, but I think all I used was this wiring diagram: https://www.arcade-museum.com/manuals-videogames/F/Fighting-WuShu--Fighting-Bujutsu.pdfI got a Cobra board. I need to make a power supply, but I'm curious what the 3.3 volt connector is divided into purple and blue wires. Are both purple and blue 3.3v or some other voltage?
thank you! I will try to make it well while looking at the wiring diagram. I need to boot after replacing the rtc and hdd. I hope the bga isn't broken.It's been a LONG time since I hooked one up, but I think all I used was this wiring diagram: https://www.arcade-museum.com/manuals-videogames/F/Fighting-WuShu--Fighting-Bujutsu.pdf
Good luck, I hope it boots. It very likely won't, you'll need a new RTC at minimum. Very likely a new HDD, and if it was ever operated or moved, the GPU board is probably dead.
wow! thank you so much! I'll try wiring it.Hi!
I quickly scanned the diagrams.
I'll publish the rest later. I have two original Japanese manuals.
Of the two, one is a bit ugly on the outside.
I think I'll sacrifice itby removing the binding for better scanning and proper archiving.
I must have found a very good book guillotine.![]()
Power Supply original Konami Windy II Cabinet
