SNK-NEO-GEO
Enlightened
Not sure if this goes under a project but.. here it is… Kray's work is amazing.. I highly recomended Kray, he answered all my nob questions and gave me recommendations on what to use.. I received my kit on Friday and strated working on it.. I have never put anything together or painted so be gentle
Completed the cab today and play Street Fither 4.. very cool all is working..
The coin door
http://www.ebay.com/itm/360127648947
Monitor
the Shmups guys recommended DELL U2414H IPS
Used 4 M4-0.7 30mm to mount HomeDepot
Kray recommends a monitor but it is a TN panel.
Amp and speakers Kray's recommendation
http://www.amazon.com/Pyle-PCA2-2X4...sbs_267_2?ie=UTF8&refRID=01HE6R00RR0T75G60CAB
http://www.amazon.com/Rockford-Fosg...sbs_200_6?ie=UTF8&refRID=00SH8QKKSZ6RZ67KH4S4
RCA to 3.5 - to the dell U2414H and RCA to the Amp
http://www.amazon.com/Mediabridge-3...8&qid=1440252686&sr=8-1&keywords=rca+to+3.5mm
Joystick - kray has the model of the joystick and push buttons on the site. Focusattack
(Sanwa(JLF-TP-8YT) it will come with the plate.
use = 6 x 3/4" flat head wood screws Lowe's for the joystick
Ps360 - focusattack has videos on how to wire pretty much plug and play.. be very care with the USB wire that you use. For best result use a standard printer usb wire and connected to a USB 3.0 port if using a computer. The alienware has an issue reconigsing the PS360 because I use the USB cable from Focusatack and was plugging it into the USB 2.0 port. I upgraded to 1.66 firware and still having a minor issue, I have to unplut the PS360 from the Alienware and them plug it back to reconize it.. The Xbox 360 there is no issue.. The Xbox 360 will see the PS360 as an Xbox 360 controller.
http://www.focusattack.com/akishop-ps360-multi-console-joystick-pcb/
Get two of these
http://www.focusattack.com/10-connection-22-awg-110-ground-daisy-chain-wire/
One of each
http://www.focusattack.com/16pc-22-awg-wire-with-110-quick-disconnect/
http://www.focusattack.com/10-foot-male-a-b-usb-2-0-cable/
Console and PC
Xbox 360 and Alienware Alpha (mameui)
For the marquee, CP and arts Kray will give you the link. Take the file to a FedEx store for printing, mine cost $45. I used out door banner paper, the marquee does not light up as much but it does the job.
For the paint I needed something simple to use and that I could retouch in the future when it gets dirty or something happens. The only drawback about stain is that it takes a long time to dry up, over 8 hours.
Paint/stain used = minwax wood finish gunstock 231 Lowe's
Sealer = Bulls eye shellac clear transparent. Lowe's
Other items
Black tape - to cover any gap from monitor to bezel so the light does not came out from the back.
Lowe's
Wood glue Lowe's
To make the round circles on the control panel = Walmart looks like a compass about $4 called x-ACTO compass paper cutter.
The coin door
Monitor
Get two of these
One of each
Console and PC
Other items
Lowe's
Wood glue Lowe's
