Iro
Hello,
The sound of my Lindbergh is very low. The last time I used it , there was no problem.
I pluged/unpluged the PCI Card, test the jacks on the motherboard...
The last thing I made, is to changed the region and the model type.
But I came back to the original values and it doesn't work better.
Any ideas ?
Thank you :)
Not made me believe that no one has already had the problem? ?(
Have you tested another system in your cabinet? Maybe your audio amp is the issue, and not the Lindbergh?
if the problem occurs in both the onboard audio and the pci audio then I think it's likely the problem is your amp or wiring and not the lindbergh... while not impossible it's highly unlikely that both audio circuits and audio drivers in your lindbergh would fail at the same time in the same exact way.
I tested the lindy with the audio amp of my naomi : KO (same result, I have to turn up to full the audio amp)
I tested the audio amp of the Sega Rally with mp3 player: OK
So it's not my cabinet but really the lindy.
The last thing i made is to change the region and the model type.
Do you know what is "model type" for ?
thank you :)
