Lines in Foreground Sprites
Judgmentt
Hey Everyone
I have had my CPS2 Multikit for almost a year now with no issues. Recently I have started getting some lines in my foreground sprites(see photos) and I could use some help trying to track down why. I disassembled the multi-kit to check the pins and everything looks good there (photos attached). I was able to procure a second A board to test with but that produced the same results, lines in my sprites. I double, triple checked the boards to make sure everything was properly mated but no new results. Any thoughts?
Here’s a shot of the sound fix, it’s secured
Perhaps a fault in the B board itself, probably one of the customs.
Are you running a fan?
Also, ensure the A and B boards are firmly docked.
5V good?
-The fan is running, it isn't the stock fan but a suitable replacement
- A&B Boards are firmly mated
-5V is good according to my supergun
RE: Sega 16 Altered Beast Thread: That thread refers to a faulty rom chip but those chips aren't on the board anymore since my Darksoft kit took it's place. I also noticed this issue before disassembling and reassembling the multikit to see if any pins may have been bent or damaged.
I have also gotten rid of the lines on a different working A board, which makes me think it could be either the Darksoft Multi or the B board itself.
I'd speculate the B board. Those customs run hot and with a less powerful fan one of them probably died.
This might sound strange but are you testing this with the B board back in it's full case? I just had a very similar problem (almost looks the same), i re-seated the B board many times, push all 4 connectors *really* hard to ensure good contact to no avail and like you i triple checked all the multi board pieces and how they were inserted.
Once i put it back in the case it worked without the lines. Something about how the case helps make the A+B mate together evenly/easy.
Possible but if it was used for a year and it's only happening now - I'd suggest the sockets are at fault.
Looking in your picture several pins in the socket look like they are not making a good connection and this would absolutely cause lines. They're not in the sprites though they're in the fix layer
I would be checking and considering replacing your main program ROM sockets (bottom left of the board)
