Franco23444
Yep, you might want to get some longer cable, you might have some available.6 to 10 feet
So you think I should get longer versions of these?: https://www.ebay.com/itm/284221496341Yep, you might want to get some longer cable, you might have some available.
If you can find longer versions of those, then yes.So you think I should get longer versions of these?: https://www.ebay.com/itm/284221496341
This is a great example! Good job dude!For reference, here's the one I just built.
That's rad. Great job and thanks for the reference photo. You pretty much used the parts that were listed in the thread other than using a different toggle switch, right?For reference, here's the one I just built.
I used what was in my parts drawer, which has a LOT of stuff... so I crafted my own cable by attaching the three pin header and soldered on a toggle switch I had. But I have a fair number of tools such as the required crimpers etc. But the end result is the same as one of the off the shelf cables. I suspect that if you hunt around ebay and the like, you could find some pre-soldered switches (I see on off ones, but not three pin with all pins populated).That's rad. Great job and thanks for the reference photo. You pretty much used the parts that were listed in the thread other than using a different toggle switch, right?
