Lost Data pad
bartre
Nebraska, USA
so per the fixing guide, here's what I've got.
A friend got a bit too hot working on the writing wires for the multi, lost a pad.
https://imgur.com/jfTZCPs
I've fixed up the rest, but I'm not sure where I can backtrace the lost pad.
Looking at the diagram in the main thread, I think I should be fine if I go back to the far side of the nearby resistor.
That is to say, not C117, but the surface mount component on the left in the picture.
Alternatively, I could also join to the corner pin directly behind the same component, yes?
What exactly I'm talking about is highlighted in Yellow-
https://imgur.com/a/GQVx43h
Yes it should work. I ended up lifting a pad and was able to fix things by running the single wire strand to the ARM chip leg.
Generally you should be able to scrape back a bit of the solder mask and run a wire from the trace to it's intended path when you lift a pad too.
Just be careful when scraping :)
well I soldered it back on, games are registering on the LCD.
I'm still getting a blank screen (solid one color) checked my points around the jumper and still no dice.
Reseated everything and no change. And ideas?
