FS lots of PCB:CPS1,2,3 ,SNK MVS NG64 and JVS:Naomi,Triforce,chihiro,WIPI,system 2X6 and PCarcade:TTX,Lind,ring
crazyjojo
China
PCB:
Dataeast, CAVEMAN NINJA,Dark Seal / Gate of Doom,works,dirty,$188,
Dataeast, CAVEMAN NINJA,Dark Seal / Gate of Doom,works,ENG version,nice condtion,$328,
TAITO Z system,Double Axle / Power Wheels,works,¥228
Konami,violent storm,works,$588
PSIKYO SH2 ,striker 1945II, works,$188
Dooyong Super X Mitchell,works,$248
Technos Shadow Force,works,$288
Seibu ,new zero team,. works.$228
SEIBU SPI, Reiden Fighter: $260
SEIBU SPI, Reiden Fighter 2: $280
SEIBU SPI, Reiden Fighter Jet: $580
PCB, Reiden Fighter 2 PCB: $268
PCB, Reiden Fighter 2 Ver.2000(386I ): $248
Aleck64 Mickey Tetris: Currently faulty. If repaired, aiming to sell for $300.
Standard Aleck64: Can be modified for N64 cartridge adapter. works, $240.
NAMCO,system11,tekken1,$158
NAMCO,system11,soul edge,$158
NAMCO,system11,tekken2,$158
NAMCO,system11,tekken3,$180
NAMCO,system11,tekken TAG,$180
Sega,System32 multi,Out Runners,full metal case,works,$1288
Sega,System32 multi,Out Runners,no case,PCB only,works,$888
Sega,system H,cool rider,full metal case,works,$888
Sega,System32 ,RAD Rally,PCB ,works,$328,could be convert to other games.
CPS:
CAPCOM CPS1 A+B+C,varth,works,$228
CAPCOM CPS1 A+B+C, Street Fighter II CE,works,$228
CAPCOM CPS1 A+B+C,Final Fight,works,$228
CAPCOM CPS1 A+B+C,Knights of the Round,works,$228
CAPCOM CPS1 A+B+C,Captain Commando,works,$228
CAPCOM CPS1 A+B+C,rockman power battle,works,origin,$358
CAPCOM CPS1 A+B+C,rockman,works,$228
CAPCOM CPS1 A,works,$108
All ROMs on the CPS1 B-board are a mix of original and replacement chips. To avoid any dispute, they are all classified as replacements. You can also choose which ROMs you want, and I can re-burn them for you.
CAPCOM CPS2 A+B,SFZ3,phinex,green case,$368
CAPCOM CPS2 A+B,SFZ2,original roms,no case,$368
CAPCOM CPS2 A+B,Dimahoo,original roms,no case,$368
CAPCOM CPS2 A+B,1944,original roms,no case,$368
CAPCOM CPS2 A+B,1Battle Crcuit,coversion,no case,$308
CAPCOM CPS2 A mobo,$200
CAPCOM CPS2 case,green,60$
CAPCOM,CPS3 fullset of 3rd striker.All offical , CAPCOM Packaging Box,works fine.$1600
CAPCOM,CPS3 fullset of red earth,same as above,but no box.$1300
CAPCOM,CPS3 darksoft set.motherboard+SD2SCSI+naomi2 case+controller adapter.$1300
CAPCOM,CPS3 darksoft set.motherboard+blueSCSI+case+.$1200
CAPCOM,CPS3 darksoft set.motherboard+blueSCSI.no out case.$1100
CPS3 detail:https://www.arcade-projects.com/threads/cps3-3rd-striker-red-earth-draksoft-set.34327/
CAPCOM,ZN1,street fighter EX1,worls,$188
CAPCOM,ZN2,Rival Schools,works,$258
CAPCOM,ZN2,street fighter EX2,worls,$278
CAPCOM,ZN2,street fighter EX2 PLUS,worls,$348
SNK:
HYPER NEOGEO 64 Samurai Spirits 2 $288
HYPER NEOGEO 64 BURIKI $488
HYPER NEOGEO 64 Fatal Fury Wild Ambition $288
HYPER NEOGEO 64 roads edge $388
HYPER NEOGEO 64 Beast Busters Second Nightmare $600
HYPER NEOGEO 64 v1 MB base $388
HYPER NEOGEO 64 v2 MB base $388
detail:https://www.arcade-projects.com/threads/hyper-neogeo64-motherboard-and-cartidge.34216
MVS 4 slot,works,$280
MVS 1 slot,works,$110
SVC chaos PCB,$218
bootleg:
Konami,violent storm,works,$218
PSIKYO SH2 ,striker 1945, works,$78
PSIKYO SH2 ,striker 1945II, works,$78
PSIKYO SH2 ,striker 1945III, works,$78
ninjabatman,works,$78
Varth,works,$78
Cadillac,works,$98
Warriors of Fate,works,$98
Street Fighter II’CE,works,$98
Captain Commando,works,$98
JVS arcade:
Sega,naomi1,works,$118
Sega,IO-board,works,$45
CAPCOM.IO-board,clone.$45
Sega,netdimm,4.02,512M+zerokey,works,$238
JVS wipi base kit,$88
detail:https://www.arcade-projects.com/thr...-reader-webcam-joystick-ic.34351/#post-471726
Sega,chihiro type3,512M,works,$328
Sega,Triforce type3,512M,works,$438
Namco,system 246,DVD,works,$218
Namco,system 256,DVD,works,$248
GDrom driver,works,$98
ATX24P-JVS power cable,homemake.$18
JVS disc and cartridge:
NAOMI GDL-0041 GUILTY GEAR XX ACODE $137
NAOMI GDL-0011 GUILTY GEAR XX $123
NAOMI GDS-0018 Lupin III: The Shooting $247
NAOMI GDL-0007A CAPCOM VS SNK 2 $205
NAOMI GDS-0015A POWER SMASH 2 $205
NAOMI GDS-0024A VIRTUA FIGHTER 4 EVOLUATION $192
NAOMI GDS-0006 VIRTUA STRIKER 3 $55
NAOMI GDL-0039A MELTY BLOOD ACT CADENZA VER.B $178
TRIFORCE GDT-0001 VIRTUA STRIKER 2002 $41
TRIFORCE GDT-0004E F-ZERO AX $1,205
CHIHIRO GDX-0011A OUTRUN2 SPECIAL TOURS $411
CHIHIRO GDX-0012A GHOST SQUAD $205
CHIHIRO GDX-0001 THE HOUSE OF DEAD 3 $274
detail:https://www.arcade-projects.com/threads/naomi-triforce-chihiro-disc-and-key.34215/
Naomi cart CAPCOM VS SNK $158
Naomi cart Rival school $288
Naomi cart GUNDAM $128
Naomi cart NBA $108
Naomi cart sambal $118
Naomi cart Ikaruga(homemake) $108
Naomi cart sega tetris $128
Naomi cart gunspike $158
Naomi cart Heavy Metal $128
Naomi cart samba de amigo $128
Naomi cart tokyo bus $258
[COLOR=rgb(32, 64, 96)]Naomi cart slashout $188
Naomi cart MELTY BLOOD $178
Naomi cart Dead or alive 2 $258
Naomi cart Radirgy Noa $288
[COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)]Naomi cart Marvel VS CAPCOM 2 $228
[COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)]Naomi cart Power stone1 $248
[COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)][COLOR=rgb(32, 64, 96)]Naomi cart Power stone2 $288
[/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR]
atomiswave cart rumble fish2(clone)$168
atomiswave cart Knights of Valour The Seven Spirits (original) $168[/COLOR][/COLOR][/COLOR]
system256,disk+doogle,all OG:
  • Mobile Suit Gundam: Gundam vs. Z.A.F.T. II - $110
  • Mobile Suit Gundam: Gundam vs. Gundam - $110
  • Tekken 5: Dark Resurrection - $188
  • Time Crisis 3 - $160
  • GP Moto (HDD, Chinese Version) - $80
  • Cobra The Arcade (HDD) - Honestly, I don't see this game come up for sale often, so it's hard to price. I'm thinking maybe $168?
PC arcade:
Tatio,TTX2,Multi hack,500G SSD,all games,JVS IO,works,$288
Tatio,TTX2,Multi hack,SSD,all games,JVS IO,works,$288
NAMCO,N2,Wangan Midnight Maximum Tune 3,namco IO,works,$228
SEGA, LINDBERGH 7800 GS VGA,multi hack,,JVS IO,works,$328
SEGA,RingEdge,multi,SSD,$398
My CPS3 board arrived the other day and I have been loving it.
crazyjojo was also happy to answer any of my questions during the setup process!
sold a SNK MV4.
sold a TTX2 multi,with TGM3 standalone.
sold some PCB.
Is the image on both TVs from the same source? If yes, the tv on the right have too big scanlines, probably to much vertical stretch If I'm correct.
