Low Voltage Atari Millipede Arcade Machine
Rick Gadz
New User
United States
I have a Millipede Arcade game that has been converted to also play Centipede. I've owned for years and it has been working great until now. When powered up the monitor has a "garbage" screen, which I believe means that it is stuck in Watchdog Mode. There is continuous beeping. I am only seeing about 4 volts at the PCB and AR-II Board.
With the PCB disconnected, I am seeing around 5 volts. I can adjust the Pot and the voltage varies from about 4.9 volts to 5.9 volts. When I plug the PCB back in, the voltage drops back down to about 4 volts.
I cleaned the PCB connectors and Pins on the board with a fiberglass brush and spraying with Deoxit contact cleaner. Unfortunately this did not fix my problem.
Any advice on what I should check next? Should I be looking at or checking the LM305 regulator chip or the 2N3055 transistor on the AR-II board? Thanks in advance for any help with this issue.
