M72 Irem Audio Amp/Resolution On Screen
ForestOfDreams
Utah
Thought I had fixed this problem but apparently it is internal to the multi pin amp since bending it reconnects it internally.
Is there a common replacement part #?
As for the resolution, is it normal for it to take up the center third only of the screen thru a scaler?
Perhaps some jumper?
I was able to replace the chip and the audio works great now.
I think it had gotten hot and failed internally, the pads for it were unusually brittle.
As for the video, once cropped it works perfectly in a 4/3 layout but it is jarring that it is the only pcb that I have that will sync but is horrendously offset and smooshed to 1/3 screen.
It sounds like that may be normal though. If so. That would make me feel better.
