ExZX
Add me for x2. Thanks
With this install will only work on M72 motherboards + afferent sets . This multi have a exception beside the Apocalypse M72 Multi .Will this install on an M84/M82 (Major Title 1), and is there any possibility of support for Major Title 1 if using an M84/M82 as the donor?
So let me understand it correctly. The dewmansnk's MULTI is especially made for R-Type donor to play all (rest) games from M72 library.R-Type top board lacks sample capability which the others have.
The top board can be swapped, but this makes little sense as R type is now expensive and others are cheaper, and the other games with the multi can play R-Type fully.
The top board on R-Type is tiny.
It still needs finishing up, but the board was going for 70, then suddenly started going for 170 due to speculators and chancers.Wasn't Hammy working on a Hammerin' Harry m84 multi at some point? (sorry I haven't check back disregard if unhelpful)
