Main characters' indication is wrong.--SOLVED (post 11)
EEL-MAN
JAPAN
Hi,
I installed my CPS2 multi kit in a suicided jap Vampire saver B-board (revision 4).
I think it's without mistakes. I want you to tell me how to do. Please help. Please
At this rate are there no pals?
BGSB3G
Am I wrong?
I do not understand a mistake
Did you verify all the jumpers with a multimeter?
Also, is there already a jumper wire soldered on the bottom of your B-board?
Of course I checked it
I confirmed it many times
I am in trouble very much
That jumper on the bottom is meant for a G pal. What happens if you insert the PAL without removing the pin or soldering the wire to the PAL on top?
A problem wasn't settled in a regrettable thing.
Remove the bottom wire and just use a wire between the pal and J17. Its definitely some sort of B-board issue.
The problem was not able to be settled
なので which I gave up was that ZERO2 which I owned was revision 7, and I changed it and it started normally and confirmed it
I get dreamlike CPS2; is very happy
Such wonderful MULTIKIT, thank you
I looked firm and, for the solution to problem, checked it everywhere
And I found it
I spent very worthless time
When I removed ROM, the cause was the mistake that I committed
Thank you for advice!
He blew the trace with the screwdriver while removing the orignal mask roms... Ouch...
Glad to hear you got it working. Ganbatte !
