MemCard Pro2 Conversion Discussion
È possibile realizzare un multi da un sd2psx (ne ho realizzato uno per un amico e ci ho scritto il suo nome), ma non entra in un 256 senza usare un multi-tap come extende
fammi capire un po' come scrivi questo software sulla SD? grazie ancora
memcardpro2 support will come eventually, just like SD2PSX, the 8bitmods crew will add support for arcade and prototype magicgate. it's a matter of time, since they have lots of items in their TO-DO lists
FW 1.30 is officially out now, and the arcade option is indeed available - does anyone know how to create/use a dongle file like i have from Brizzo's card (.bin) to the .mc2 format for the memcardpro2?
Matt
The files I linked above need to be put on an SD card and put in your MCP2 they're all the publicly dumped dongles
Still having an issues with this on 1.41 - I have put the files (.mcd files linked above) in the root, in ps2, and in ps1 directories I can't see them at all in the web interface to select - I have verified that "arcade" is select amd the MCP2 shows "8MB" on the OLED.
Any hints?
Any hints?
I really have no clue I don't own one I just resigned memory card files that were already available I don't know if the mcp2 used a different container format when it comes to saves send me over a save that you know works and I could try rebuilding them based upon how I see them built
It's the same than SD2PSX but with .ps2 extension IIRC
Also, mcpro2 needs external power in order to be ready when arcade OSDSYS looks for boot.bin
Any hints?
Did you power it externaly
