I can tell you it's not. The 1A PALs all game specific. and there are more than one version just for Mercs depending on which B-Board it shipped on
That is "O224B"Third Line (faded): 02248 or 02246
I don't think it will help, it's not graphics related.I see there's another GAL16V8 rom at 11E. Should I just flash a new chip there, too?
it's really not. I'd even argue it's one of the more common arcade hardware.I know CPS stuff is rare as heck
Every corner store almost had a SF2 world warrior, Champion Edition or Turbo out my way. I would have thought it was the most produced arcade hardware ever, but I could be wrong.it's really not. I'd even argue it's one of the more common arcade hardware.
it's entirely possible.Every corner store almost had a SF2 world warrior, Champion Edition or Turbo out my way. I would have thought it was the most produced arcade hardware ever
Great info. Pacman and Space Invaders were before my time.it's entirely possible.
If I recall SFII was the 3rd best selling arcade game of all time. Pacman sold around 400K cabinets and space invaders around 360K cabinets
SFII was a distant 3rd at 200,000 (between all versions) But given how many other great selling games came out on the hardware the total number of units sold across all CPS1 might have pushed it to #1
Based on what I see on the market though I'd guess that MVS is the most common arcade hardware, potentially with CPS1 at #2. I've seen it quoted that 1.18Million MVS units were made... and I believe it.
Thanks, Big_P. I might as well check into it again. I will say, though, that I've use the Mercs board on 3 different PSUs (Astro city original, some junky cheap thing in the Mercs cab, and a new meanwell). It has the same bars. I also have a Ghouls n Ghosts conversion which works perfectly on the Astro and Meanwell.Great info. Pacman and Space Invaders were before my time.
MVS boards are definitely the most common on the market now and 1.18M sounds more than realistic. The cart system was a great selling point and really set the standard for easily swapped games. In the arcade i used to work in as a teen, we would have had 10 or more MVS boards and very rarely was one out of a cabinet. Compared to maybe 6 CPS1s on the floor and numerous in storage or later in the systems life swapped for newer games with the local distributor.
On topic however, I wouldn't rule out it being a PSU issue just yet. Jailbars like that can show when the amp draw is too close to the PSU max. I note that you have adjusted the voltage but this will not necessarily fix an amp issue. I had a similar problem with a CPS2 recently and adjusted the voltage up incrementally to about 5.1v with no success only to find later that it was infact a PSU issue and I was drawing just over the PSUs max amperage. A bigger PSU fixed the problem. I wouldn't rule out a board issue but it's definitely worth looking at the PSU before you start pulling other stuff as it's an easy test.
I just reread the bolded. Thanks for the tip. Would you or anyone else recommend restoring the battery on this B-21 c board?before you go soldering stuff confirm it's the c-board. either send your C-Board to someone who has a working MERCs board, or have someone with a working mercs board send you their c-board.
alternatively if you or someone else has a battery backed C-Board it can be reprogrammed for MERCs and tested on your board.
the last thing you want to do is mess up a reflow on your C-Board if that isn't even the problem
