PascalP
Legendary
I think I’ll source a 22p connector to use that connection for a MC Cthulhu.
But that might be a project for the slightly longer term
Thanks for your good advices.Actually, you can produce this to work for every PCB on the market; add in screw terminal posts to breakout the button mapping. Maybe sliding screw posts on the other side of the joystick mount for a separate screw down PCB mount. But I understand your design choice. You want to ship out a working joystick, not a vessel or empty shell for a controller PCB. There are some aesthetic things that can be improved upon that will make functionality better. But I have no problem with the technical aspects of what you have produced and will be an early adopter to support your efforts. Your pricing is excellent.
I can make it work with the MC Cthulhu; just requires a 2.54mm pin header and Dupont wires. I'll end up recycling the cheap Chinese PCB that you include (it's a Xin Mo 1-player PCB I believe) for a separate MAME project so that won't go to waste. Actually saves me from buying another J-Pac (which I am starting to dislike alot). I'll definitely swoop up a pair from you in a week or so.
and with all those beautiful console RJ45 wires.1 have just ordered two cases, 1 red and 1 white. I plan to use ithem with my two MC-Cthlhu and full Sanwa controls
Let's see![]()
Exactlyand with all those beautiful console RJ45 wires.![]()
Which pictures ?@hursit your pics are down...?
Thanks for you advice, I attach to the siteDon’t see the last pictures about the packages.
I use Imgur myself but as you can’t use it you could try stuff like tinypic?
Not sure if other good alternatives are out there?
Or make sure the pic is less than 1mb and upload it here to the forum as an attachment to your post![]()
