Hey @Frank_fjs I really like this project. I used your minigun advanced design as the basis for a supergun I designed a couple of days ago. I changed up the layout a bit, and changed the power connector for an ATX 20 pin (I have a lot of ATX power supplies laying around) and also a 6 pin JST connector in case I get a proper arcade PSU. I also changed the 8 pin Mini Din for a 9 Pin and deleted the capacitors and resistors on the THS7374 output so it will work with Genesis model 2 SCART cables. Controversial I know, but I've got several high quality Genesis 2 SCART cables so it works for me.
https://oshpark.com/shared_projects/pfBALSG5
This particular version of the design hasn't been tested yet, but the first revision has been manufactured and tested. All the issues that I am aware of have been fixed at this point. I'll follow up once I've built this version of the board.
