Missing PAL16L8 on the board Jaleco City Connection
Just making sure you have tested all the components leading to that pal? also the ones its connected too? and the socket? If so i will need to take a look at mine when I have the time and see how the sync circuit works
I tried to draw what the situation is there.
Probe i meant. U gonna have to get the databook out for all those ic in that circuit u drawn. Or buy a slice unit which does the legwork for u.
I took out all the ttl ic that has to do with the actual GAL.. I checked it based on the functions of the eprom burner ttl test. all are fine
I would personally probe them in circuit to see if i/o have signals on them. Chips make pass but if they arent being activated it can help u find the fault
