If you're using a JPAC and an HDMI to VGA converter was involved, I'm fairly certain that whatever signal you fed into the Astro City was either scaled, interlaced, or both (can MiSTer even output low res via HDMI? I'd have to check... *EDIT: A dumb question if I thought about it... I use a JAMMA Expander which connects via HDMI so the answer is yes). If any of that happens it tends to look pretty bad on 15khz monitors.
If you used the analog IO board of the MiSTer to connect the NNC, it will usually (but not always) output the same signal as the original console/arcade board, so you can expect the NNC to look pretty good.
