MiSTer Ironclad Case
FrancoB
UK
I finished this recently and thought some of you might like to see.
Finished picture first:
So, earlier last year I picker up a couple of DE10 Nanos. I originally ordered a RMC MiSTer Multisystem to put one of them in but after hearing cools thoughts on the one he bought I cancelled the order. cools then found the [MiSTer Mini-ITX Ironclad Plus] which is basically a Mini ITX form factor IO board. This looked to fit the bill much better and so I picked one up too.
Looking back I ordered the Ironclad at the start of March last year :wtf: However I didn't actually receive it until September so I guess four months isn't too bad to complete a project once I had received the main parts, certainly better than 10 months I guess!
I was looking for a Mini ITX case for it and coudn't really find anything to suit my needs exactly and thought it might be fun to try and make something. I couldn't do too much until I actually received the Ironclad board but I started to mock up what it might look like. This was a bit of very early development:
View: https://youtu.be/ICiLlHDbLjM
The ITX mobo, SSD, USBs and button are just some random .stp's I found online to get started.
The plan was a 3D printed frame with a mixture of printed panels and tinted acrylic for the top, front and bottom. I wanted to see if I could fit and mount a SSD in under the Ironclad and I planned on adding a couple of USB ports on the front and a LED ring power button.
That's most of the spiel done. I did take a fair few more pictures whilst working on lots of the parts. If I get time and there is any interest I will upload them along with some notes. Otherwise most of these pictures are of final assembly.
Ironclad mobo the day I received it and sat on one of my 3D printer sheets. As you can see it just fits with room around it to print the frame:
Printing the corner pieces:
I had previously built a press for inserting threaded brass inserts. I actually built it with this project in mind as I knew I would have loads to insert and they all needed to be perpendicular to the printed parts:
A load of other parts printed:
Assembled:
Acrylic top and bottom panels. These were made on my router table and hand polished:
Front panel. Once again made on my router table. I've got lots more info on these steps I can post later. I used some 2m USB extensions for the USB ports:
Side panels. I originally printed the two left hand panels. Just before Christmas I visited a laser manufacturer and had access to a machine for the afternoon so I cut the panels on the right. The whole design is fairly modular so the panels can be swapped out fairly easily:
I had some issues with the MiSTer stickers curling up at the corners. I managed to make them adhere a little better using some 3M spray mount but they're still not perfect and I'm trying to source some better ones.
1TB SSD with a SATA>USB cable that I cut off and added a pin header connector to:
Top removed and side panels added. These pictures are with the 3D printed side panels. I swapped them out for the laser cut ones later. I fitted a PWM fan to the LHS side. There are PWM fan headers on the Ironclad and there is a temperature sensor under the DE10 so the fans will run at the minimum speed required to keep the DE10 cool:
I made a couple of mods to the underside of the Ironclad. I added a jumper to bridge two pins for use with adding a I2S DAC to the top side of the motherboard. As I was mounting the SSD under the mobo I added a connector to the USB through holes rather than run a cable from the top side to the bottom. I also tapped composite sync at the top of the board so I can add a composite sync phono jack for use with Guncons:
I'm limited to 20 pictures in a post so I'll continue below...
One part of the undertray fitted to the mobo:
SSD and tie wraps added. The tie wraps were actually added before the under tray was bolted down:
Wired up:
Bottom cover fitted:
Bottom panel fitted:
Top side. The I2S DAC is just to the left of the MiSTer logo with the green wiring:
12v in and composite sync phono jack. Due to how the phono jack needed to be bolted to the case I wasn't able to fit it once the case was assembled so I added a 2 pin header so I could just plug it in once assembled:
Top panel on. Excuse the dust :roll:
A few assembled pictures with the 3D printed side panels:
Swapped in the laser cut side panels:
Continued in next post again.....
In it's main resting place in my office. It's quite easy to take downstairs though and plug into the living room TV too:
All in all I'm pretty happy with how it turned out. Not pictured is multiple redsign/reprints of parts, buying the wrong tint acrylic and a load of other fuck ups along the way. Maybe more on those later :whistling:
It would have been faaaaaar easier and cheaper to buy something off the shelf but where is the fun in that :D
Damn, that is a nice ironclad setup. I like mine for the most part. My only real complaint is I've never got any of the fan configs to work. I really hope that gets better in a later revision.
Cheers guys ^^
It's been a bit of a labour of love, sometime more labour than love but I'm glad to have it off the books so I can concentrate on some other stuff.
A few people asked if I could make them but there's about ~25hrs printing time alone (I've probably printed 50+ due to developemnt and smurf ups :whistling: ) and that's without the plastics work etc.
I am going to uplaod the .stl's though (and .stp's, we need more of a .stp revolution!) so people can print their own if they want. I realise the Ironclad is a bit niche but it meets Mini-ITX specification so normal ITX mobos would fit too. You don't need the undertray stuff if you don't want any you could just use 14mm spacers instead.
Thanks man. Can I ask what issues you've had? I have a PWM fan setup and I've left it on auto. It seems to be running at minimum speed and I can feel cool air being exhausted. To be fair I've probably not really had it on long enough to build up a lot of heat (if they do get hot) and seen if the fan speed increases.
I have two of them, and they are the later revision with the addition of arcade mode, silent mode, etc. For one of them the fan auto sensing works just fine. After playing a game for a bit the fans do come on. On the other one, it didn't seem to work. In both of them I checked and made sure the temperature sensor was bent up and touching the mister. Both seem fine and undamaged.
On the one where auto sensing didn't seem to work, I figured I'd just configure it to run the fans always. But I couldn't get that to work either. I know from setting arcade and silent mode you need to press the button very fast (all presses in about one second it seems). But no matter what I tried I could not get the fans going. I tried on the other one too and no dice there either. So on that one I just took the fans down to two wires so that they are on whenever they get power and that's been fine.
It's not a huge deal, overall I'm still very happy with the ironclad.
Have you released the stl files for this amazing case? I would love to fit my ironclad into one.
I've not uploaded them as yet but I can do.
I'm happy to share files but there is not much point uploading .stl's due to the inconsistency of acrylic thickness. I ordered my ~5mm acrylic and I measured each piece in multiple places. The variation was about 0.8mm in some places and so I modified my model to suit each acrylic piece so that the veritcal sections of the case were a nice snug fit. I also modified the recess in the the top and bottom so that the horizontal panels were as flush as possible too.
A better idea would be upload .stp's that can be more readily modified in CAD software to suit your material. Let me know if that works for you and I can look to collate files and get it uploaded. I can upload an assembly of the whole thing so you can see what goes where. If you can't modify .stp's let me know and we can go from there. I could maybe change some of the slot witdths/recesses to be more of a baggy fit but it would need some work.....
Update whilst I'm here... since changing CRTs the case now lives in a console rack I made. More details on that [here].
Thanks for your quick response. I will be more than happy with .stp files as I can work with both. I would be even happier if you could adjust slot witdths/recesses to be symmetrical as I plan on printing the panels for now with my Bambu until I get a lasercuter for the plexi.
Thanks again I love this design!
Okay, leave it with me. It will take a bit of time to sort, collate and upload everything. I don't have models for all of the panels as I made some of them on my router table. If you're going to 3D print them I'll need to create models for them too.
Okay, spent all last night on this so far. As it was a personal project I didn't have models for eveything or have everything assembled in CAD so I've put a lot of effort into making everything as complete, informative and straight forward as possible.
This is where I am currently:
Everything now has a model. I've even added the correct varying length bolts to the assembly so you can interrogate the model to see what goes where. I've added the heat set inserts too so you can see where they need to go in various components:
I've included the laser cut side panels, it's doubtfull the laser cut fan panel would be printed but I've included them in case you wanted to make a .dxfs from them for laser cutting. If I get chance I'll try and dig my .dxfs out or create some more.
Front/back/side panel slots are all 5.2mm. The panels are all 5mm. If you're prinitng all of the panels you can scale/mod the parts in CAD or your slicer to adjust the Z height/fit.
Top and bottom recesses were 5.5mm so I've left them as is. The top bottom panels not have models and I've made them 5.5mm thick too.
Now I have everything in an assembly I can export the whole assembly as well as the individual components to .stl and .stp.
I've got some router template models to upload too in case they're useful for anyone else as well.
I've got family over this weekend so I'll get the last bit done next week and uploaded to Printables.com with some notes.
Wow, you went above and beyond!! I can't even begin to explain how much gratitude I have for this! Thank you so much! I have a friend with a laser cutter I might have to visit as it looks too good with the acrylic panels.
Thank you for your hard work and for going out of your way to get this done.
Enjoy your time with family FrancoB!!
Will anyone be willing to produce a few for those of us that dont have the time or equipment to make it. Im in for one.
