Mortal kombat 2 no audio blast city
ghantz
italy
Hi,
I bought a board of mk2 but with my blast city I can not hear the audio.
The problem it's that my jamma connector don't have - 5v it's correct?
There is an adapter to resolve this problem?
Regards
Than I connect this converter between mk2 board and jamma of my blast?
Just like this...
Ok, have you measured. Does it work? Does the board get -5v?
I know my Negatron has a small adjustment pot as well for the voltage
It's correct this screen?
I can't hear anything, no sound only background noise
The display is showing you +5v from pins 3 and 4. You need to measure -5v from pin 5 using a multimeter.
Mine also has a small adjustment knob. This photo shows you the small gold knob near the “adjust” label.
Also I would adjust your +5v power so the meter reads 5.07v or so.
heads up. sometimes the cap by the back of the audio amp heatsink will go bad from the heat. if that cap is bad you will also get no audio even when you do get -5v to the board. the phillips caps that williams used were crap and commonly are dead at this point in time.
