SlipDerMan
Hi my friends,
I'm having a little trouble getting Shadow Dancer to work on System 18.
I have two types of motherboards:
* one with 2 oscillators
* the other with 3 oscillators.
I'm testing all of this on different Blast City arcade cabinets (one with an MS2933 board, one with an MS2931 board, and one with an MS2930 board)... when I use Shadow Dancer with the 2-oscillator motherboard, I get a synchronization problem and a blurry image on the screen. However, regardless of the Blast City cabinet used, when I try Shadow Dancer with the 3-oscillator motherboard, the game works perfectly on all three cabinets.
A friend gave me some invaluable advice (Dom, you're the best!), which was to connect pin 14 of the JAMMA connector to the 4 GND pins (1/2/27/2
. That's what I did, but I'm still having the same image synchronization problem with the dual-oscillator motherboard.
Do I need to change the GALs? Is there something I need to do on the boards?
Do you have any suggestions?
However, I tested the Shadow Dancer + dual-oscillator motherboard on a Euro arcade cabinet and via a Supergun, and it works perfectly... it's only on Blast City machines that I have image problems.
Thank you for your help.
This message will self-destruct.
Best regards.
. That's what I did, but I'm still having the same image synchronization problem with the dual-oscillator motherboard.Do I need to change the GALs? Is there something I need to do on the boards?
Best regards.
