SNK-NEO-GEO
Wow we.. Love it man.. Ohh why is it that I do not have someone with your skills set close to my area.. Love that Ashtonishwave.. Ship it to me
Im not that familiar with the Blast but I have investigated this for a AC or NAC.Wow ...That's just amazing !!! thanks for shearing.
I wonder would this work for a sega blast city or a sega astro city ?
I'm curious which (true flat) 29" CRT tubes you are referring to. I guess you mean 29" TV tubes? If so can you recommend any TV brand, models? I picked up a Sony KV-E2961D as backup for my MS 2930 but that tube is actually a bit smaller then the Toshiba tube. What would be the 'perfect' CRT TV alternative for a 2930 in your opinion? Or a general good arcade CRT => TV model alternative?Result:With a lot of help and prototyping from a friend on a Swedish forum we managed to create some rot-mech arms that fit a true Flat 29" CRT tube.
The arms was made for a LG/Phillips tube but also fits other tubes as the Matshushita/Toshiba Pure Flats.
Doh!No TV tubes here.
The 29" inch flat tubes I am using are from the Toshiba Pure Flat Arcade monitor, Tri-sync and can be found in a NNC with the chassis D29C051. Amazing monitor.![]()
It can have a Toshiba tube or Matsushita.
One other flat arcade monitor I tested was a Wei-Ya with a LG-Phillips tube, it did fit in the rot mech but the picture was not even close to the Tosh PF, so I sold it.
Are the measurements in the various diagrams the final ones? If so, I wouldn't mind looking into having a few kits made up here in the states. Friend of my father owns a metal shop, so I'm sure I could at least get the metal parts done no problem. And my father's a woodworker by trade.Produce kits would be nice but that is for someone else to do.
I got help from many people over at different Arcade forums with manufacturing the parts and they did the parts in their spare time.
I was more like the planner and tester.
Then name it "Monouchis Rotation Mechanism"Are the measurements in the various diagrams the final ones? If so, I wouldn't mind looking into having a few kits made up here in the states. Friend of my father owns a metal shop, so I'm sure I could at least get the metal parts done no problem. And my father's a woodworker by trade.Produce kits would be nice but that is for someone else to do.
No idea where you'd find the plastic roller things though.
Perhaps we can work together as a little community to put a bunch of these guys together?![]()
Just to double-check, these measurements are for the Toshiba PF?
The stock AWSD flat-screen will not work?
Thanks.Nicely done man. This could not have been easy. This was an amazing amount of work and incredible end result!
Thanks supa!Hey Monouchi,
Excellent work on that rotatable monitor setup! Seriously sweet and ignenious!
On another note, I noticed in your sig that you're looking for an Egret II 1l6B...
There's someone on shmups posting a few(though they look like copies, but thought it might interest you![]()
http://shmups.system11.org/viewtopic.php?f=4&t=57093
But of course it should be named Monouchi's Rotation Mechanism!Then name it "Monouchis Rotation Mechanism"
Seriously though, with the right tools you can make one of these pretty quick.
The diagrams are final, the wooden board one is very messy though and needs some fit-testing if done again.
