MS-2934 horizontal waviness - shake, and flyback anode clip issues [fixed]
MagicianLord77
Montevideo, Uruguay
Hi guys, this time I'm working with this untested MS-2934 chassis I need to bring my chassis-less Crazy Taxi to life, I'm trying it in a Naomi Universal Cabinet.
It does mostly work, it came it with a bent anode clip, and was missing green but found it was because of a light crack at the neck board, patched the traces and green came back :)
Now the other issue it has is horizontal waviness, and fizzling / popping noise from the anode, this is the anode clip I've bent in several ways to make it fit the tube hole but somehow I can't figure out what's its proper shape, does anybody know? rubber cap was already a bit cracked but on the inside.
No matter the way I bent and attached it, it would always make a slight fizzy noises, and changes on the noise seemed to correlate with horizontal waviness in the picture, so I replaced it with an oldschool clip from a new generic flyback - couldn't fit the metal cap on it so left it like that.
Then turned it on, and not much did change, still similar noises and waviness. Also as it was before, upon power up there is a lot of intense waviness that slowly improves 15 minutes after, but it does not seem to go away, this is the best it gets to look:
https://imgur.com/a/60MzvTj
This is the previous clip that I would like to use if I knew how to bend it :(
Any tips to improve anode connection? is the waviness really related to it?, I'll be trying with some dielectric grease. Thanks!
Ok so I took a good looking clip from an old for parts Kortek chassis, then at the Nanao, when I was taking away the clip I had soldered in the anode cup, the wire came off, so it seems it was already a little weak or something, maybe the bad contact was because of that.
So had to strip a bit of the cable, bent the wire backwards. place the new clip and solder it in.
After that no more noises, anode connection is good and secure :)
But the wavy weird issue persists. Now I noticed it quite improves after 30mins, but it never goes away. Waviness changes with picture brightness. Might be time for a full capacitor replacement..
Replacing the capacitors did the trick, the waviness issue is gone! works flawlessly so far, looking bright and sharp :)
(must adjust some pincushion)
There is a capacitor list over here: https://www.arcade-projects.com/threads/retro-hardware-capacitors-lists.10800/post-407752
But I anyways noted them down including more details, to just out of curiosity see how many were really bad, and there were quite a few with at least 20 times the ESR of a new capacitor, that's not good. On the outside they were all fair, no signs of rust or swelling. I guess their rated life was over and ESR began to rise?
Hope the data can be interesting:
