I'm trying to troubleshoot an MS8-29 with a dim picture.
At first I just figured it was an old tube. Happens. I did a full recap of the entire chassis just to be safe, no difference. We put a rejuv on it and ran the the tests, and the guns were definitely low. But after some rejuv cycles everything was all the way up in the green, so I figured we'd see at least some improvement.
Nada. Just as dim.
This made me suspicious there was something else going on, so I measured the voltage at pins 9 and 10 at the neckboard, which should be 6.3v. I was getting 2.9v. Welp, that sure seems to explain it.
I checked the B+ for the chassis, should be 94v I believe, it was dropping down to 91v after warming up. Adjusted it back up to 94, no difference.
My next working theory is that this was maybe a tube swap, or a mismatched neckboard, something where the heater resistor wasn't matched up right. Checked the resistor, it's 4.7ohms, which is standard for the MS8 as far as I can tell. But still, if there was a mismatch maybe it was still wrong.
So I picked up a handful of different fusable resistors to experiment. I'll skip to the end here, I went as low as 2.2ohm instead of 4.7ohm, and the heater voltage only went from 2.9v to 3.3v. Enough that I had to turn the screen pot down slightly to get the blacks back, but hardly brighter.
Then I measured off the first leg of the resistor to the neckboard, and got 3.8v. Which seems to confirm the issue is before the heater resistor and there's not a mismatch, the voltage is just low.
Going to try and trace back and check components, but if anyone has seen anything like this before and has suggestion for things to look at all ears.
Nada. Just as dim.
