NFGx
[UPDATED: see solution post below]
So my MS9, recently returned from a service, has developed a serious problem.
Once or twice before it has turned on from cold with a very impressive blur problem. Like, 20% of the screen sort of blur. It resolved gradually over ~5 minutes, and then didn't happen for a couple of weeks, but this time it's started making a fizzling noise at the same time. The brighter the screen, the fizzier the fizzle. Then I noticed a subtle flicker in the brightness levels. And then, after re-seating the neckboard and checking all the wiring for loose bits, it started to flicker with horizontal lines, as if it was trying to collapse vertically.
It's going back for a second look from the shop, but I'm wondering in the mean time if anyone has any ideas about the cause of these symptoms?
Attached is the blur. You can see by the light reflection that the focus on the camera is good, but that rolling static background and text display from a MiSTer board are completely fucked.
