MV1FZ sound error [Solved / Neo-C1]
Retro Mecano
Tunisia
Hello,
My MF1z plays games fine, except for sound when starting the playgame. Menu is ok, character select is ok, but when after selection i can hear the starting neogeo logo. In addition starting the level will stop the music and sounds. Exactly at the same position every time.
I got with diag rom and cart the exact same error everytime. z80 dead.
Excpexted :3C
Actual:4C
Tested all continuity between Z80, Ym2610, Sm1, D0, C1 and cart port pins.
Changed z80 anyway, 6116 and checked the sm1 rom. No change.
1 year ago, Board already recapped, a0 amp changed and battery removed. Worked like a charme
What to see next?
Are you using a cart with the diag m1 rom on it?
The version I pointed at is newer.
Anyways, Both sides (68k cpu and z80 cpu) are complaining about bad communication with the other. That communication is mostly handled by the NEO-C1 and NEO-D0.
https://wiki.neogeodev.org/index.php?title=NEO-C1
On the NEO-C1 I would check the SD0-SD7 pins going to the z80 and D8-D15 going to the 68k cpu. The 3x SDZ* pins which should come from the NEO-D0.
https://wiki.neogeodev.org/index.php?title=NEO-D0
On the NEO-D0 I would check SDW (comes from NEO-C1) and NMI going Z80. MREQ and IORQ pins which should be coming from the z80.
I Made a new burn with the link you shared, and i got this message (same prrrt sound, and 001100 beep) only thing changed is "excpected" is 3C. Was 4C before.
Checked also all continuity you mentionned. All ok.
There are some details of how the comm test works here
https://github.com/jwestfall69/neogeo-diag-bios/blob/master/docs/tests/comm_test.md
But the gist of it is
Code:
   1. bios: wait for HELLO (0xc3) message
   2. m1 -> bios: send HELLO (0xc3) message
   3. bios: accept HELLO (0xc3) message
   4. bios -> m1: send HANDSHAKE (0x5a)
   5. m1: accept HANDSHAKE (0x5a)
   6. m1 -> bios: send ACK (0x3c)
   7. bios: accept ACK (0x3c) message
   8. m1: test clearing the receive data port
Your picture implies the path from m1 -> diag is working ok because diag bios got the 0xc3/HELLO message and sent back the 0x5a/HANDSHAKE to the diag m1. However it would appear the diag m1 never got that message. The sound latch (in the NEO-C1) should get updated when the 68k writes a byte to address 0x320000. I would try checking the following on the NEO-C1
A17-A21 should go to the 68k cpu
A22I-A23I devwiki says those go to a NEO-E0
R/W, UDS, LDS, AS, DTACK should go to the 68k cpu
On the NEO-E0
https://wiki.neogeodev.org/index.php?title=NEO-E0
A22-A23 should go to the 68k cpu
Its of course possible you have a faulty NEO-C1 or something else.
Code:
On the NEO-E0
Just rechecked all of that.. all connections are like described..
Not sure how to feel about it lol.
Noticed one thing, start+select does not work in diag bios. They work fine in unibios 4 to soft reset.
This is usually caused by your supergun/cabinet having the select button wired to insert coin instead of select.
So anyways, after all these checks, is it a verdict Neo C1 is failing, or still a chance another minor component is out?
The fail is confusing me because the slot is absolutly not heavily used. May be played once a month for 1 or 2h..
