Muchi Muchi Spork
No I'm saying use 27C4096G for the 3 program roms 21, 22 and 23. That's all you have to do. It's the easiest conversion ever.
So I was looking at the board.. and was like.. OH sweet capcom used UV chips.. I'll just back those up -- uv them and write rainbow to them.. after 30 minutes the chip didnt erase.. so back to placing my order for them.No I'm saying use 27C4096G for the 3 program roms 21, 22 and 23. That's all you have to do. It's the easiest conversion ever.
#!/usr/bin/perl -w
open LO, $ARGV[0] || die $!;
binmode LO;
open HI, $ARGV[1] || die $!;
binmode HI;
my $hidata;
my $lowdata;
while (read(HI, $hidata, 1)) {
read(LO, $lowdata, 1) || last;
printf "%c%c", ord($hidata),ord($lowdata);
close HI;
close LO;
ROM_REGION( CODE_SIZE, "maincpu", 0 )
ROM_LOAD16_BYTE( "dmu_29.10h", 0x00000, 0x20000, CRC(334d85b2) SHA1(89bacc28b7c799c7568420e3de5a99060baa7b0f) )
ROM_LOAD16_BYTE( "dmu_30.10j", 0x00001, 0x20000, CRC(cee8ceb5) SHA1(fc8db1ce0c143dfda0b5989d02d5e5a872e27cd2) )
ROM_LOAD16_BYTE( "dmu_27.9h", 0x40000, 0x20000, CRC(4a524140) SHA1(cebd651293c3570912d5506c1c223c39bcccc802) )
ROM_LOAD16_BYTE( "dmu_28.9j", 0x40001, 0x20000, CRC(94aae205) SHA1(514b3c1b9b0b22300a94229825c3be66332ea5ed) )
ROM_LOAD16_WORD( "dm-17.7j", 0x80000, 0x80000, CRC(3ea1b0f2) SHA1(c51f1c38cdaed77ad715cedd845617a291ab2441) )
./ans.pl dmu_29.10h dmu_30.10j > first.bin
./ans.pl dmu_27.9h dmu_28.9j > second.bin
cat first.bin second.bin > damj_23.8f
cat 26.10a 26.10a > dam_09.12a
ROM_REGION( CODE_SIZE, "maincpu", 0 ) /* 68000 code */
ROM_LOAD16_BYTE( "ffu_36.11f", 0x00000, 0x20000, CRC(e2a48af9) SHA1(11e06f95bdf575af396dded2b84d858f6c7388f1) ) // in "30" socket
ROM_LOAD16_BYTE( "ffu_42.11h", 0x00001, 0x20000, CRC(f4bb480e) SHA1(32114df1d2f4f98a4a2280a330c7b6af8ab4d862) ) // in "35" socket
ROM_LOAD16_BYTE( "ffu_37.12f", 0x40000, 0x20000, CRC(c371c667) SHA1(633977c91a8ff09b7fe83128eced7c4dee9aee1d) ) // in "31" socket
ROM_LOAD16_BYTE( "ffu_43.12h", 0x40001, 0x20000, CRC(2f5771f9) SHA1(fb532402bc00b5619a23dfa7e4525f1717020303) ) // in "36" socket /* different CRC from ffightu, ffightu1, pcb verified */
ROM_LOAD16_WORD_SWAP( "ff-32m.8h", 0x80000, 0x80000, CRC(c747696e) SHA1(d3362dadded31ccb7eaf71ef282d698d18edd722) )
./ans.pl ffu_36.11f ffu_42.11h > first.bin
./ans.pl ffu_37.12f ffu_43.12h > second.bin
cat first.bin second.bin > ffu_23.bin
CRC(bd41c4e1) SHA1(16482fbac2b5396b2ff2f4645ec999a8f650a1d3)
Just do those two hex changes, burn the chip and enjoyPunisher normally requires the CPS 1.5 hardware for music. There is a bootleg version that will work on your SF2CE but the music will be all wrong.Is there anyone that can put Punishier on my SF2CE PCB?
This is great. I assume you can do the same thing and make Strider resale too?SF2CE to Area 88 Resale version:
Really easy conversion, it uses the same B board. You need area88r from Mame for this
GAL chip is "ara63b.1a" run it through jedutil in mame to convert to .jed and write
GFX chips for slots 01 through 04 are:
ara_01.3a
ara_02.4a
ara_03.5a
ara_04.6a
Note 2 & 3 might have to be swapped depending on if you have a MASK board
Audio cpu in chip 09 is ara_09.12a
Samples in chip 18 is ara_18.11c
Program 22 and 23 are:
araj_22.7f
araj_23.8f
Probably... I paid apocalypse for that conversion though so I never bothered to look into itThis is great. I assume you can do the same thing and make Strider resale too?SF2CE to Area 88 Resale version:
ara_01.3a
ara_02.4a
ara_03.5a
ara_04.6a
araj_22.7f
araj_23.8f
Thank you in advance for all !
