I need this! Currently using an SD2IEC but the Pi solution seems much better, and less expensive than some of the other solutions.
yes.. you can define that fb64 (the menu) loads in the emulated drive everytime you reset the C64. You can then fire it by LOAD"*",8,1 or by Commodore+RUN/STOP if you use a fastloader (I use the Epyx Reloaded one".So without a separate HDMI display or onboard OLED display, one can still navigate files via the C64 itself?
Guessing you just load a file from the C64 which invokes a browser of some form?
