Hi Guys,
Currently i'm using 12V and 5V for power, VGA and Audio from JST but Jamma for controller.
but I noticed that the board does not start if I connect the controllers before turning on.
So i need to power the game until it boot up, and after connect controller.
the problem might be that I'm not using the JVS USB controllers... maybe.
But checking Blueretro adapter we have a JVS solution:
https://github.com/darthcloud/BlueRetro/wiki/BlueRetro-Cables-Build-Instructions#jvs-adapter-cable
What you think ?
From what I understand if I use and the 12v and also 5v the board expects the jamma, but the jvs ports are active.
EDIT: Ok i found that the problem is on power supply, with my banch power supply 700w its work always fine with both controller connected.
damn i have to change it.
What you think ?
