Namco system 256 no sound and image
The 2X6 will not boot up with out a game in the system. Also, some games support 480p resolution via dip switch settings. Normally the system will display in 15khz 480i/240p resolution which most modern VGA compatible displays can’t process hence why you’re getting “invalid format” on your display.
I need to find another monitor?
No, you can use a converter instead. Something like the GBS-8200 will work and is currently the cheapest converter to buy.
I have this TV, my bro said it should work with sys, but there is no vga. Can I use vga to hdmi converter? Will it work in this way?
Put all the dipswitch 234 in on position and put the vga cord direct to the namco system 256
Plus what is the game in the system if it's like soul calibur 2 or 3 open the metal case you can see that there is a 246+/256 jumper in desire game like tekken 5 the jumper tab must be in 256 mode
It's cobra the arcade
