Nanao MS8-26 jitters
LSVegas
Germany
I have a Nanao MS8-26 which is jittering, shaking horizontaly. More noticible on a grid then in game. In game it looks more wavy. Chassis had been full recaped some years ago. i did a capkit as well with more quality caps, except the big filter and two values i didn't had. Does someone know what can cause this issue? Don't have a stepdown transformer in the cab and the pods for hold or phase do nothing.
I would do a reflow on all the neckboard and pretty much on the entire chassis. Try this before attempting to replace other components. That is not cap related.
I would check the anode cap. Make sure the connection is good and the vacuum cap has a bit of dielectric on it. You can try repositioning the anode connection a little by rotating the cup slightly. This seemed to solve the issue on a couple monitors I have here doing something similar after verifying that the chassis itself was not the cause.
Obviously, following all the standard rules for touching the anode. Only do it when the monitor is off and be sure to discharge it beforehand.
The big cap is typically a filter cap.
At this stage I would assume it might need replacing though it might not solve the issue.
Arcadespareparts&repair typically carries obscure/large caps/bipolar caps.
After many recaps on chassis, I lost the belief of the cap kit. Unless a cap phisically looks damaged (leaked or bulged) I always leave them alone. Inspect the RGB transistors on neck board. Broken traces or cold traces might be the issue.
After 30+ years if I am pulling them to measure it they are cheap enough to replace imho, and they do dry out & change value.
I understand not everyone does this, but for personal projects then it will be good for my usage/lifetime if I use premium branded caps.
I strongly caution against using cheap brand capacitors, unless one likes recapping often.
I'd be curious to see a video of the jitter? I know that disconnected or poor quality ground can cause something that I'd describe similarly to this(unfortunately, I do NOT have a video showing what I mean).
Can’t supply a video. The image is shaking optically. If you look close, the right pixel (seems like a blue pixel) of a line is flashing on and off, creating this effect. So I thought about something in the blue circuit maybe causing this. It’s grounded correctly, but will check this out as well.
Had it back on the bench. Reflowed a lot of joints, changed a tental 1uF 16V near the HA11423 changed the last caps I didn’t last time, anode cup repositioned and fresh grease, checked the pots. Nothing. Problem still exists.
I would rule out interference, cause when the monitor is our, no change. As far as I know, the only ground coming from the video and power cables. The frame isn’t mounted to ground on that monitor, or am I wrong?
Check the anode cap. Make sure it is clean and the reorient the clip slightly by twisting it to the side slightly. Apply dielectric to the rubber boot.
The large filter cap almost never goes bad.
It’s exactly like in the video but a little more subtile. It’s effecting the whole screen not just a side. As I said, checked and cleaned the anode cup, applied new grease and changed the tental cap, like in geekmiki‘s thread.
When you replaced C430, did you take out the vertical deflection PCB?
As I mentioned in my thread, I am not sure if C430 was the real culprit, but reflowing the vertical PCB might have helped too.
Yes, pulled it out. Did it also before. So every pin is resoldered twice. It’s not a problem of bad soldering. Checked every trace and resoldered every suspicious pin.
If you think the chassis isn't the issue, it might be a good idea to inspect the yoke.
I've have a friend who had a monitor with some unexplained jitters/waviness due to a disconnected winding within the yoke. After soldering the winding back, it worked perfectly.
This will require you to remove the yoke and check inside for any issues with the windings or perhaps some debris that got lodged in somehow.
