Nanao MS8-29 narrow / wide
Bluechen
Germany
Hi guys simple question on my Nanao MS8-29 there are two pins one is labled narrow and the other is labled wide.
there are two cables, a black one cominf from the ground cable and a white one from the chassis.
please tell wich cable comes on wide and wich on narrow. thank u !!!
The white cable must go on narrow, the black one goes on the neckboard. In my case, the white was on narrow and the black on wide, which led to image errors.
i literally just did this on my ms8 25 which is identical to an ms8 29. narrow and wide are for your horizontal width. start with that connector on normal and adjust your h size. if you cant get wide enough with that, plug the wire into the wide pin.
