Nanao MS9-29 enhancement hacks
I have some MS9 chassis that have different neckboards. Can't find a D506, r517, so I thought it might be an older revision, but I can't find a J404 on it either! It's marked 05a00675c1.
Is it possible to do these mods on this chassis?
Also does anyone have photos of what the edge curling looks like?
You can do it on any of them fundamentally, but sure enough it's possible the jumper name is different or gone. Ultimately you just want to isolate that neck pin from ground and instead substitute the G1 voltage.
Thanks. I guess I'll go and check the chassis that I've installed on cabs. maybe I'll find one that is similar to what you guys used. Just too much work to try and figure it out with these spares I have.
Thanks for this topic and with the help of a friend we did the sharpness mod. For me the end result is a very noticeable. Sharper and thicker scanlines. Only had to turn the screen pot a little bit to make the screen a bit brighter and that's it.
Before and after.
Did anyone perform the 31k mod on a MS9-29SU with a Hitachi tube? When i do it, i get massive rollover on the right side, even with a freshly recapped chassis.
Would love some help on how to fix this.
Hey guys. I attempted the 31k mod. G1/Sharpness worked. Replaced the resistor with a 15k, swapped the geometry caps, then swapped the connector to 24k. When I tested it, I heard an extremely loud squeal from the monitor so I shut it off. Restored the caps and I still get the same loud squeal. What did I do wrong? How do I fix it?
You said you did the Sharpness Mod first and it tested ok?
yes, it looked great, actually!
So I went ahead and tried the 31khz mod. I swapped the 22k resistor for a 15k, then replaced the geometry capacitors. Moved the connector to 24k and tested. Maybe I missed something? Did I need to set the HH24 pot before testing?
I have another Chassis that I'm willing to try this on. Just really want to get 31khz running on my other Net City.
It also might be worth double checking your work on the sharpness mod. I had a chassis I recapped last week that worked great on first test, then had sync issues later. Needed to fix some already re-worked areas and it’s all good
The sharpness mod worked perfectly. It's something I did with the 31khz mod that messed up the board.
nem: I don't feel any static.
