WTB Nanao MS9 Chassis
Want To Buy
Hydreigon
U.S.
I feel the only way I can repair my dead MS9 is by swapping parts from another. My suspect bad component is transformer T901 in the power section.
That is a weird failure item though. I have some of those chassis in Canada
Swapped a bunch of components (flyback, vertical sync IC, horizontal deflection IC), tested HOT, replaced the mofset. Chassis worked fine plugged in from a Motocross Go cab until I unplugged the chassis (from the power plug at the chassis) while the cab was powered on. A voltage arc happened somewhere in the chassis killing a part that can only be obtained from another chassis (or something else).
Namco cabs like these were probably designed for something NOT to be unplugged while powered on and using components as a test bench from the cab was probably a big mistake.
