I haven't turned my Naomi on in a while and when I did I got no sound. I found that if I turned it (Capcom IO) up to about max, I can barely hear the game playing. I ruled out the amp because my CPS2 outputs nice and clear when hooked up to it. I connected a regular audio source on the input side of the IO and when going through the amp, the music sounds fine. So that leaves me with the motherboard. Since the sound is coming out, it sounds like either the caps or filter board are the problem. But since the audio section is just line-out, would the caps have much effect there?
