Naomi 2 - GPU Fans Not Spinning
tika
Australia
Hi all, just wanted a sense check - if the 2x GPU fans on Naomi 2 mobos are not spinning (ie: filled with gunk), will the Naomi 2 boot/display video output at all?
The backstory is that I've recently purchased a Naomi 2, and didn't boot first up, and upon checking the GPU fans, they're filled with gunk of sorts and wont spin at all. I've also checked the voltages on the PSU (I'm using a 750w ATX PSU - that's all I had lying around), on the mobo and the fan headers, and the 5v rail is very close to +5.0v
Naomi won't boot if the fans on top of the processors aren't spinning. It's a safeguard.
Thanks for the confirmation - I suspected as much as I thought I had read it somewhere before.
Is it possible to fool the Naomi 2 in thinking the fans are OK just so I can see if it POST/boots to a screen at all? Can I connect any 5v fan to the 3-pin header on the Naomi mobo or something else to get it going?
Thanks for the link mate - I've checked my Naomi 2 with the ATX PSU I have connected to it (Corsair HX 750i) and it's a solid 3.15v at the JST plug during power on and afterwards
That's low. It should be 3.3V.
You can try, but not all fans will work.
See this thread for working replacements:
That's good to know - thanks! I've tried a different ATX PSU (PicoPSU) that I had lying around, and it outputs a solid 3.3v on booting up the Naomi 2 and once it's running. I tested the 12v and 5v rails, and with the 5v rail being 4.97v, and the 12v rail coming up as 11.87v - are these close enough to boot the Naomi? If they are, then I'm suspecting the janked up GPU fans are preventing the hardware booting up.
Either way I'll grab a couple Noctua NF-A4x10-5V fans to test if the mobo actually boots with the GPU fans spinning
5V is a bit low, but it should boot. 12V doesn't matter. Ideally you would have an arcade PSU that you could manually adjust the voltages with.
Try replacing the fans.
So an update: I bought 2 new GPU fans (Noctua NF-A4x10-5V) and switched the pins over so they work, but no video output from the Naomi via the VGA port on the device. I checked the CR2032 battery, and it was dead so I replaced it, to no avail.
I connected a JAMMA to JVS adapter, and into my supergun, and still no video output from the Naomi, so I'm thinking it's dead.
I have a Virtua Tennis cart in it to test - will the Naomi boot/produce video output without a game plugged into it?
Sure will. It will boot an error screen and you can enter the service menu.
Obligatory reading:
Any sound?
black screen is usually bad ram but could be many things.
If you put a Naomi 1 game in it will disable the extra naomi 2 ram and try to boot so try that first.
Also make sure you wiring on the new fans is 100% including the 3rd sense wire for the fan speed
And wait a bit ... some noamis take longer to boot. (30-60sec)
check the back / front of the i/o board if there is maybe a burned trace on the VGA connector line
Is the dip switch (on the i/o) set to 31khz? :)
the system fan is spinning?
Is your monitor capable of picking up the signal (i had some TFT Panels where i could not get an image)
sadly in most cases with black screen it is one of the rams :(
Obligatory reading:
Thanks for the info and link - I've had a good read over the post and have checked the voltages at the PSU and the various voltage test points on the Naomi 2 mobo - all look to be good (also very similar to the voltages in the thread you posted).
I've checked the voltage on the VGA port on pins 1 and 6, and am seeing ~0.0v there. I checked the pings 1 (Red, 2 (Green) and 3 (Blue), but they all show 0v. Interestingly the H-sync (pin 13) and V-sync (ping 14) pins show +5v when the console is powered on.
I've also tried both the RAD2x and a GBS 8220 (VGA) device inline from the Naomi VGA port to the monitor to check if there's a some scaling/sync issue with my monitor, but still am not seeing any video output using either of these devices in 15k or 31k video output mode. Sound output is also no existent.
After a few mins of being on, the various IC's are warm to the touch, but sadly not seeing any video/audio output
Any sound?
No sound at all from the Naomi 2 - I've used different speakers to check, but still no audio output from the N2.
I can verify that the new fans are working and the sense wire is in the correct position. Not sure if my monitor can handle the Naomi video output, but have tried multiple in-line VGA devices between the N2 and monitor, just incase there's something going on with the monitor. I've also tried different monitors and 15/31k video output modes, but still nothing is displayed.
It's looking like it's the RAM after trying multiple monitors, video settings and no audio output from the N2. In saying that, I checked the voltage between pins 1 and 6 on the VGA adapter, and it read 0v. Checking pins 2 and 3 to 6, also showed 0v. I traced the pin 1 on the VGA adapter and it buzzes out to ground - so it may have a short in the filter there. Are these known to fail?
I took some pics for posterity for the various JP points on the N2 mobo. I also took a few pics of the N2 mobo underside - looks like there was some work/reflow done. Is this normal for a stock N2 mobo out of the factory, or does the below indicate some work was done on the board previously?
This looks like very old flux - And the flux is on places were normally repair would not have been done (but i may be incorrect on this)
If you still get a black screen it is 99% one of the rams.
I would remove this Supercap (and before that please receck if this is the supercap) and check if some of the traces around it are gone
Btw are you running with stock bios?
Apologies for the delayed reply. I had a look at the flux and does look like it's very old, so I also suspect its from the manufacturing process.
I've removed the supercap and it doesn't look like it has eaten any tracks around it. And yeah, running the stock BIOS that's on the Naomi 2. Will changing it out to a different BIOS make any difference?
Yeah I thought that also, so will get a new BIOS and see if it has the same issue. Thanks!
