Naomi 2 - ic29 testing bad only with netdimm attached
8lall0
Italy
Hello,
i have a problem with my Naomi 2 with multibios.
When testing it, without the netdimm the IC29 tests good, but there is a small artifact (image on bottom).
This artifact shows even on standard boot (which is giving me ERROR 01)
When testing with netdimm, IC29 tests bad.
I suppose i can assume IC29 is bad?
I have the supercap removed and no battery on the system.
Plus, can a Naomi boot into network with the netdimm if it is not connected? Just to make sure it's ok.
Thanks!
I've had a graphics glitch issue like this on a Naomi 2, it was tricky to track down as all the rams passed. I ended up using freeze spray on the video rams one at a time until the glitch went away. The only issue was I replaced the ram and the issue didn't go away. Turned out the freeze spray also cooled the ram in the same spot but the opposite side of the board. :hilarious: Once I replaced that ram the issue went away.
Bad video ram won't cause error 01 though, that's usually bad connection, bad cart or wrong region set.
Ok, i excluded the naomi with the netdimm (carts are working, just glitchy), while the netdimm is bad.
I'll try when i can to diagnose the bad ram.
