Mrhide
but of course! here it is:Very interesting, can you please dump the EPROM and share it ?
I don't have another IO.Do you have any other JVS IOs ?
Do you own a HAS ?
Just to be 100% sure try swapping the USB cable to another type.
Place your DMM on the 5V JAMMA edge on your JVS IO and hold it there during the complete cycle, see if it dips at any point.
If you have a HAS try powering the JVS IO with that instead to make sure you have a stable power source.
I also recap my PS ahead of time ( I don't believe it booted at all without it).I really glad you're getting this resolved. I've seen many crazy NAOMI voltage issues but this is one of the weirdest for sure.
I don't trust the blast to power more than a cart setup, similar to Capcom IO. I recapped my blast but I still don't trust it to power a netdimm setup by itself.
There's always the AC connector in the blast to add a sun psu for the naomi, and power the IO from the JAMMA harness.
should be CN13 - AC output. Same pcb in the cab that you plug the kick harness into.I also recap my PS ahead of time ( I don't believe it booted at all without it).I really glad you're getting this resolved. I've seen many crazy NAOMI voltage issues but this is one of the weirdest for sure.
ac connector for a sun PSU ... interesting. will investigate
