updatedVirtua Athletics supports local 4 player. will work with 2x chained JVS IO, will not with single Capcom IO set to 4P mode.
Please elaborate. Who has it? I did a conversion some time ago but there is a difference in Hardware that makes it lag a lot.This seems like the right thread to ask in. What about House of the Dead 2? It's not on the list, but some folks seem to have it netbooting/CF booting on your average run-of-the-mill Naomi 1.
Thank you for the solid answerTyler was on this forum, too, before he vanished from every forums.
He told me some times age his version doesn't work well, not finished. And he will never finish since he left arcade scene.
I wonder what revision NAOMI he's running... I wonder if it would have run properly on an early revision NAOMIThat video looks exactly how it looks when you try to netboot on a normal naomi. It runs EXTREMELY SLOW and is missing a lot of gfx.
It does't. A bios that supports a Dimm is required to use the Dimm. HOTD2 will only work with it's own bios. I did try the hotd2 bios on newer Naomi and also does not work.I wonder what revision NAOMI he's running... I wonder if it would have run properly on an early revision NAOMIThat video looks exactly how it looks when you try to netboot on a normal naomi. It runs EXTREMELY SLOW and is missing a lot of gfx.
it require mobo with X76F100 SN# eeprom (near CPU), while newer mobos uses 93C46.I did try the hotd2 bios on newer Naomi and also does not work.
