Naomi to RGB on PVM?
does anyone know of a comparable model to the 580xi that will fix my sync issue on my D24 so I can play Naomi in glorious 480p / 31khz?
I think anything in the Extron RGB range should work
  • RGB 109xi
  • RGB 120
  • RGB 201rxi
  • RGB 202rxi
  • RGB 203rxi
  • RGB 202plus
  • etc.
I can probably scrounge up one I'm not using if you are buying.
edit: I have a NAOMI and a BVM-D32. I don't have a CBOX Supergun. So I'm not sure if I can test it for you or not. Is there a way to hook it up with out the CBOX?
Ended up purchasing a used RGB 192 from eBay. I actually spoke to a salesman at Extron earlier today and he mentioned this unit should work fine. Also quoted me at $700+ USD for one which I politely declined.
But if you have a 201, 202, etc you'd be willing to let go please PM me as I'll take one with the screen on it :)
