wasspat
Hi guys,
I have a problem with netboot with my Triforce Type 3.
I have put the two jumper on ON : check!
I put my net zeropic : check. (my zero pic is totally functionnal with my Naomi, so I guess it's good)
I plug in my crossover cable : check.
SoI think I follow the procedure as explained here https://www.arcade-projects.com/threads/updating-a-triforce-type-3-to-use-cf-cards-tutorial.18576/
The problem is that when I enter in network config to change the IP adress, it gives me "communication error".
I have tried with PC and raspberry and nothing helps.
Any tips? Maybe the dimm of triforce is faulty?
Thanks you by advance
