It was working at the beginning, before the socket installation. Then I tested the game with the socket and I had the same white screen (with few peace of sprits). I thought maybe the pal is dead, so anyway we must swap it to the gal. I installed the multi but same result, bad luck. Do you have an idea of what chip might be faulty ?Double check all the pins are sitting in the sockets.
If you put the original ROMs and PAL back in does the original still work? (I assume you tested the board was working ok before)
It s my mistake I think. Don’t worryFor my part, all the units I have sent to Darksoft were tested directly and even each of the 8 banks, on my Rastam board.
No same white screen with small peace of spritesIf you undo the process and put back your roms and the pal does rastan work again?
I will try to repair it.then something went wrong when socketing that PAL. Take it to someone that can repair PCBs to fix it or get a new rastan if you can.
