I imagine there are not enough NOS B21 chips available for purchase. Even if there were, that would unnecessarily drive up the price of the kit.But then again, thinking about it some more, if the multi can already accommodate a B21 why not just have them included by default pre installed into the multi and omit the need for a separate C board entirely?
Doctors what is my prognosis?IF you are transplanting a B21 chip you are going to need experience with hot air rework and SMD based soldering (yea that shit is HARD/deal-breaker for 90% I'd say).
Compressed air good or certain alcohol with q tips or none of the above?Give that board a good clean before you think about trying to remove the C custom or anything else. Dust getting in the solder or flux is going to cause you all kinds of problems.
SF2CE is the batteryless version, so needs some reworkCompressed air good or certain alcohol with q tips or none of the above?Give that board a good clean before you think about trying to remove the C custom or anything else. Dust getting in the solder or flux is going to cause you all kinds of problems.
Yeah definitely needs a clean. Plays well though, got it in advance of the Multi. Can you tell if it has that battery b-21?
Arg. Ty. Outsource things I need soldering anyway.SF2CE is the batteryless version, so needs some reworkCompressed air good or certain alcohol with q tips or none of the above?Yeah definitely needs a clean. Plays well though, got it in advance of the Multi. Can you tell if it has that battery b-21?Give that board a good clean before you think about trying to remove the C custom or anything else. Dust getting in the solder or flux is going to cause you all kinds of problems.
You heard what the boss said. Update my place for two kits when these finally drop.save for 2. I think you will want more than 1 when we release it.
Sorry @Frank_fjs , responding to this. bad etiquette on my part.Exactly that. As I wrote either you transplant any B-21 to the multi, which right now is something I'm reconsidering...or use any C board that has a B-21 with battery.
If you have a C Board with a B-21 but without battery, then you need to make some changes on the pin 42 and 43 IIRC, so it will work as the ones with battery.
I created this thread just for you: What Donor Board to use for the CPS1 Multigot it in advance of the Multi. Can you tell if it has that battery b-21?
I think that we'll give up on the transplanting option and although it's implemented we may remove it in the final run. Too much trouble.@Darksoft well, I for one vote to wait so that [ if you are unlucky enough to have a battery-less C board] transferring the B-21 chip isn't necessary. It is delicate work on 2 expensive pieces of hardware that I prefer to avoid if possible. If it's unavoidable then hey, that's the nature of the hobby and it's the risk you take but I feel It would benefit both parties the most in the long run to just wait [until you can finish whatever alternative you are reconsidering].
Unless I have this all wrong and the alternative is to only use a battery powered c-board then i guess it is what it is and just ignore me.
if it's implemented you might as well leave it implemented, it's a nice option for those that have the skills and access to a donor chip, Just leave it as an undocumented/unpromoted feature.think that we'll give up on the transplanting option and although it's implemented we may remove it in the final run. Too much trouble.
Q-Sound board is the "D-Board", it's an additional PCB sandwiched between the A and B boards (so the board stack goes from bottom to top: A - D - B -C)The Q-sound portion is contained on the C-board (I guess they refer to it as C+D)
