Brentradio
What?It's time for your daily CPS1 thread check!
You only check this thread once a day?
: looks at list :You only check this thread once a day?
Pretty sure it's CPS1The multi replaces the B and C boards, correct? That being the case, what type of connection is used for the kick harness? The CPS1 or CPS2 connector?
I currently only have wiring for CPS2, so was curious if I should go ahead and pick up a CPS1->2 kick harness adapter.
Ah but remember... Darksoft has said the multi will replace both the B and C boards (C is where the CPS1 connector is located).Am 99.9999999% sure that you need a CPS-1 kick harness for the CPS-1 multi.
You got to see mine yesterdayI have not seen a jnx cps2 to cps1 adaptor in a while and not available on his site to purchase either
Actually, no it doesn't make sense. It's CPS-1 hardware!Ah but remember... Darksoft has said the multi will replace both the B and C boards (C is where the CPS1 connector is located). How do you know DS won't just include a CPS2 style connector on his multiboard (would make more sense don't you think)?Am 99.9999999% sure that you need a CPS-1 kick harness for the CPS-1 multi.
I bought a CPS1->CPS2 adapter from this nice guy called @Lemony VengeanceThe multi replaces the B and C boards, correct? That being the case, what type of connection is used for the kick harness? The CPS1 or CPS2 connector?
I believe it's still in the works but he lost a shipment of UD-USB adapters and replacing those took priority.Dunno if the list is still being updated at this point, but I definitely want to throw my hat into the ring for one of these.
It's looking more and more likely that this is the only way I'll be able to have 1941 playable on my vertical set up. I'm also wondering if Undamned's Infinikey is still in the works (he hasn't updated for a long time), so this may be the only way to play some of my failing CPS1 B+C boards.
Yeah, that's what I saw. Pretty rough on him, I'm sure!I believe it's still in the works but he lost a shipment of UD-USB adapters and replacing those took priority.Dunno if the list is still being updated at this point, but I definitely want to throw my hat into the ring for one of these.
If you have suicided boards you can revive them using an Arduino/battery until InfiniKey is available, if your B and C boards are actually faulty then yes the multi will be a good option.
