AlxUnderBase
Enlightened
Exvania sir , from the start... Exvania is what i like the most, this because i dont have yet a vertical arcade setup
I hear you,Exvania sir , from the start... Exvania is what i like the most, this because i dont have yet a vertical arcade setup![]()
Exvania!!
Yeah also tennis has 4 player so it's worth a go, namco "kick" harness / connector should be easy enough to find just needs a bunch of extra wires adding.What!? I had no idea Knuckle Heads supports 4
players - that sounds wild!
I will need to build a link harness one of these days for some of the 4p games, I know Numan Athletics and Exvania both support it too.
Yes indeed, needs the original mother, it's a rom board.Hi there ! Nice project !
Is a motherboard needed for this or you have some to sell ?
Tried to search for those but no luck yet.They are on japan every week and tennis etc shows up often in europe and is a good donor.
Don't waste money on a faulty one just spend a little more on good, the motherboards have a leak problem.
There is a bit of a scramble for them at the moment, after the 'hype' dies a little i'm sure you will pick one up.Thanks for the reply Hammy, and yes I am familiar with the issue. I bought a faulty one and trying to see if I can fix it first![]()
Not sure I am searching correctly... would sure love a heads up if you see one around someday![]()
Meh... I am more pessimistic about that XDThere is a bit of a scramble for them at the moment, after the 'hype' dies a little i'm sure you will pick one up.Going rate has doubled! It should calm back down (hopefully)
Kicking myself for not grabbing a Emeraldia that was listed for over a month at 160.. Today's searches provided nothing available. The hunt continues
