Just tried this and it works great, thanks so much for adding it
I had already added a two pin right angle JST NH connector for the audio contact so luckily I already had a pin connected to ground. Not quite-so-fortunately when the female housing (not pictured) was connected it was nearly blocking the 5v pad but I managed to get a wire on:
I had made a Sun ATX PSU 5v power adapter for updating the CPS2 multi so I made another adapter to fit that to the STV. The .100" dupont contacts were a
really tight fit on the 8 pin header but I just managed to squeeze them all on. It's not ideal but they did all make contact with the pins and it flashed successfully first time.
I routed the reset wire through another dupont pin so it can be disassembled easily. I just used some kynar for that as it's not really carrying much current.
Fitted the internal 3 pin JST NH connector back up and soldered the reset wire to one of the spare case mounted NH header pins
Soldered the reset wire to pin 8 on IC 12 and then ran that to the JST NH connector on the case:
All done :
I'm using a DPDT power switch to turn the 5v/12v on/off when selecting the dips as I don't like to turn my monitor on/off unless needed. To be fair I could just use this instead of the autoreset mod but where's the fun in that?
Thanks again for providing the update and instructions darksoft, Mitsurugi-w and anyone else involved
