WTB open jvs cable
Want To Buy
giuliaisonfire
italy
Hi, I bought a Noami some time ago with the open jvs modification. Now the cable that connects to the Raspberry no longer works and I always have a board error. I'm looking for where to buy the cable again that will make everything work again even if it's that of a printer I noticed that what he had was different.
Thank you
Is this the cable that you’re looking for? It’s a USB-A to USB-B cable and can be found at most electronics stores.
TOPS sells the original cable for Naomi.
thanks for the reply, this is the cable, I've alread
y tried it with a printer cable but nothing, the cable I have has a resistor and seems different, that seller is in Japan and it's difficult for me to buy
I would like to know if there is anyone who can make me a similar cable, thanks
See here:
https://github.com/OpenJVS/OpenJVS/blob/master/docs/hat-quickstart.md
Jumpers​
If you are using a Pi4, you can have JVS / Serial and Bluetooth all running together. For this the jumpers must be aligned to the LEFT.
If you are using a Pi2 or 3, you can only run JVS and cannot run Serial or onboard Bluetooth at the same time. The jumpers should be aligned to the RIGHT.
Thanks for the reply, I would like to understand where I'm wrong.
So I did a new installation of the SD by downloading Wipi. I updated to the latest version, connected the Noami and everything works perfectly.
He sees my controllers and lets me set them up.
I put the jumpers as in the photo but it doesn't work but I also tried all of them on the right
I always get board error.
I start crazy taxi but nothing works, no commands work.
I would like to understand where I'm wrong, thanks
You appear to be almost there! :)
So you have a rasberry pi 3 if you tried them all on the right correct? if so put them ALL of the right.
Can you show us your connections?
the square on the hat goes to the JVS on the naomi right? and the controller to the pi USB?
Where do you see the "board error"? Can you post a picture please?
thanks for the reply, I'll start by saying that the old USB modification has always worked for me, the cable broke and I wanted this solution which seems more solid to me
With the jumpers placed in this way the SENSE lead lights up the problem that during the boot of the games the RX does not light up and I always have a board error.
I installed the latest version wipi 6.9 from code I removed bluetouth.
I can see the controllers but I can't understand where the problem could be, thanks
on wipi I have no problems it saw the dimm and sends me the game without problems but before the game starts with a board error otherwise everything loads fine, thanks
1- is the usb wire properly connected to the naomi? sorry I don't see it yet! So I'm going to assume it's not plugged in ! :D
2- is that usb wire is properly connected, is it a good cable? can you try another one?
yes of course I tried 6 cables, some new ones but I always have a board error, what could it be?
I repeat, I already had the modification working and with this hat it doesn't work
