I have a few openkeys available.
Prices assume paypal FF and don't include shipping costs.
openkey-cps1 semi-kits have 2 different types of 40pin male connectors you can choose from. Normal ones that are targeted for CPS1 games, and bare pins ones for CPS1.5 games in a case. The latter requires I bit of extra work to solder/install as talked about here.
openkey-cps2 requires some soldering, please read and understand whats needed in the install docs.
openkey-kabuki and dead battery society mod conflict with each other. Details on how to identify and remove the dbs mod can be found here.
ITEM | PRICE | AVAILABLE | SOLD | NOTES |
openkey-cps1 | $30 | 0 | 41 | Limit 2 per person, will assemble on demand |
openkey-cps2 | $5 | 0 | 433 | Limit 6 per person, will assemble on demand |
openkey-kabuki | $10 | 0 | 52 | Limit 2 per person, will assemble on demand |
openkey-kabuki-cr | $5 | 0 | 0 | Limit 2 per person, will assemble on demand |
D9K2 programmed GAL | $3 | 3 | 8 | Updated GAL fixes a compatibility issue with openkey-kabuki and infinikey-kabuki on cps 1.5 92636D-3 revision D boards. If you can burn your own GAL16V8, this is just d9k2.9k from mame (found in a couple cps 1.5 game romsets, ie slammast). |
updi programmer | $6 | 17 | 3 | Only useful if you are making your own openkeys or want to re-program an openkey |
neogeo diag AES prog board | $20 | 3 | 0 | You will also need the latest neogeo diag bios, will assemble on demand |
neogeo diag MVS prog board | $20 | 2 | 0 | You will also need the latest neogeo diag bios, will assemble on demand |
NEO-ZMC IC | $2 | 30 | 0 | New old stock NEO-ZMC chip for neogeo CHA diag boards |
