PGM mobo with broken cart slot pin...replacement?
opt2not
Multi Boyz Pixeler
Legendary
Multi Boyz
California
Hey all,
I've got a PGM mobo that has a missing broken cart slot pin. The mobo itself seems to be working, ram tests all check out, boot image is clean. but when it plays the cart there is all kinds of corruption on screen and most cases, crashes.
I looked at the cart slot and noticed it was missing a pin.
Then shaking the mobo had something rattled inside, and sure enough it's the missing pin.
Does anyone know what the cart slot connector part # is? Or if anyone sells spares? I was thinking if it's a cheap enough connector that is available, I could try replacing this slot connector before replacing the entire mobo with another one.
