VectorGlow
- Joined
- Nov 14, 2015
- Messages
- 57
- Reaction score
- 18
I've never repaired a PGM motherboard before (have repaired plenty of other board types though), now I have one with three carts in an unknown state.
Without a cart inserted the board produces a jingle, displays the PGM logo and enters the test menu.
I have three carts to test, all purchased 'as is' so basically in an unknown state.
- With 'cart A' inserted a momentary screen of garbage is displayed followed by the PGM logo then test menu. And that's it.
- carts 'B' and 'C' just boot to garbage, nothing else. Flipping the toggle switch achieves nothing (other than a blank display as expected), pressing the test button changes the screenful of garbage to a different screenful of garbage
There's no battery on the motherboard, no corrosion in that area either. Have thoroughly inspected both sides of the board for any badly corroded or broken tracks and all is well. Cart connectors are good, pins clean and straights.
Out of interest, is there perhaps a 'better' BIOS for test purposes? The label is missing from the BIOS EPROM but in the test menu the top right corner displays: V0001-001
(You could check continuity to the connector, not even power should be connected...)
